Bringing the Cat back...enough is enough.
Well damn. Looks like I've missed a real sh¡t show, huh? I don't know what it is all about just yet so I don't know where to point any fingers... but in the mean time, the current off-topic argument needs to not go any further past this point. No more at all. Period.
I've gone through and cleaned this thread up so that we don't lose a good thread because of some idiots. With that said, if this thread turns into a shi%t show again people are going to disappear from the forum.
Last warning.
SquareRoot
Good job, gentlemen, let's all try to remember to behave like reasonably responsible adults.....
Well now that @Old77 cleaned up the thread I probably lost my status for "most viewed threads" for the week :( It's the little things in life...Lol.
Last warning.
There you are picking up my slack again! I fell asleep instead of fixing it all last night, lol.
Good to see the corn sifting post remains, I got a real kick out of that one :rofl:
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Any particular Cat recommended over others?
I do not know enough to recommend a specific brand. If I had it narrowed down to a couple of choices,and no other criteria, I'd buy a high flow cat, the one with the highest shipping weight. Stands to reason it would have more content,whether it is the actually catalyst material or the casing wall thickness.
Catbox
Peter
C20 Silverado Camper Special
I just had to make this decision for my kids Camaro.
There are the super cheap ones on Amazon, I don't put much faith into them actually doing much at all to scrub the exhaust.
I spent some time looking over the interwebs and ended up spending $126 on a Magnaflow that is robust and has a much thicker core than the cheapies on the Amazon.
I also noticed that the Magnaflow I picked had a "EPA Compliant" rating on it.
I took that as meaning it would actually perform a service other than making it so that I could pass a visual inspection...
The center of the cat body is the actual width of the material, unlike the ones online that are supa cheap.
Now, I haven't completed the exhaust yet so I have yet to see if it actually works and passes the DEQ sniffer test.
This is just my recent experience with having to purchase a fresh cat for a car.
You may have a totally different experience than mine.
Ken B
indiana
ken
Good Read....
I am gonna do a cat. just wondering if its duals?
My son is trying to talk me into ceramic headers, stainless exhaust , duals, no cats.
This is a truck not a racer, he had a 9.6 second 392 charger w NOS.....the old man wants a good quiet exhaust the lets the motor breathe as much as is needed.
duals or a 2.5 inch single????? your thoughts /experience?
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Good Read....
I'm always about duals myself. But a 2.5" single seems a little small maybe 3" single would be better.
SquareRoot
Magnoflo. I did a LOT of research when I put this together. See post 41. I'll try to dig up the part number for that cat. It was slightly different from the rest in that it is CA rated. All that means is it has more catalyst and cleans the exhaust better than the same non CA version. Still a high flow unit.
Some pitfalls to avoid. It needs to be hot to work. The hotter the better. The closer you can get it to the Y-pipe flange the better. My first Y-pipe was 2-1/2" diameter. Big mistake. It shed heat way to fast, I remade it with 2" and the difference was noticeable. Ceramic coating or wrapping the Y-pipe would also help. Since I shi*t canned the headers and used the Holley Manifolds (ceramic coated) it solved the issue.
SquareRoot
Good Read....
Dual cats on long tube headers isn't gonna work well if at all.
SquareRoot
The other very useful thread on this topic:
jlyon1006
