Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
So many of you know ive put alot of personal time and money into my suburban to make the "all around" rig it is. It tows over 6k good, runs down the highway at 85-95 mph with yelling its head off, i can hit 65 mph from a stop in about 9 or 10 seconds. Big ****, Whatever. Im working on a all around truck performs like a newer truck. I know it'll never be a new truck, but my goal for it was to be reliable, not a falling apart shitbox that can barely make it to the gas pump.
SO, i have alot of big dreams for over the winter. One being, my front suspension and steering on my suburban. Its time has came, i was inspecting it all, its getting worn. And presumably the worn out front swaybar bushings and shocks is what is causing my front tires to "bounce" and cup them (thats not really the discussion here)
I will be replacing tie rods, centerlink, pitman arm, idler arm, both upper and lower balljoints,upper/lower control arm bushings, and upper / lower sway bar bushings as well.
I want recommendations for brands. I dont want a bashing session either of fuggin oreilly masterpro either.
****'s junk. You know, i know it, we all know it.
Give me some feedback guys!
It'll be getting a total front end overhaul (2wd), and then an alignment and new front tires.
Thinking 600-1000$ would be the most i wanna spend on physical parts.
I do all the labor, i have all the tools for a total IFS service/overhaul on hand.
