brand new blower motor!!!
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Ok i bought a brand new blower motor from lmc truck. I got it in and it came on but it sounded like it was rubbing on something. so i pulled it back out, and checked it but couldnt see where so i put it back in and same thing happened. So i pulled it again!! And when i put it in this time. It doesnt come on at all just a quiet clunking noise. Im pulling my hair out on this. Could someone try and tell me whats wrong?
hirschdalechevy
norcal
rich
k-30
I would pull it out and run it off a batt. on the bench and see what it does , then you will know if the motor is good.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
How do i hook a ground to it? When its on the bench?
Stroked
Beloit, Kansas
Jared
Just touch the ground wire on the case somewhere like one of the screw holes.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
I hooked it up with the ground on the firewall and hooked a jumper from the power terminal on the blower traight to the battery and where i hooked it to the battery it was smoking. And it didnt come on!!!!
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I'd send it back. I remember there was a thread on here where a blower motor off a 91-94 gmt400 would work better(move more air), and would be a direct fit. I can't seem to find it though.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
I just dont understand why it worked when i first hooked it up but now it doesnt! Did something burn it up? Im lost on this.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
I took the plug out of the blower motor and its definetly fried.
MrMarty51
Eastern Montana
Martin
Made in some foreign country where the peoples hate Americans, I suppose.
Do`nt smoke no foreign cigarettes either.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
I dont know what the hell is wrong with it. Could the capacitor be bad and not fluctating the volts correctly to yhe blower? Or could the switch be bad?
chengny
Did you have it indexed correctly? There is a locating pin on the housing that must line up with the hole on the fan mounting flange. If you were one screw off (either CW or CCW) the fan would be cocked and not center in the hole through the firewall.
When you tightened it up - maybe you bent the shaft (or the fan blading) enough to cause it to seize?
I am not explaining this well - maybe this will help:
Cantrell299
