Brake System and Combination/Proportioning Valve Diagnosis
coachdtierney54
US
C30
A trailer brake controller. If the larger is for the front, then why did I fill that one when bleeding the rear brakes?
Sent from my XT1710-02 using Tapatalk
87V30
USA
Kevin
V30
@coachdtierney54 Is that a tee fitting coming out of your forward most port on your MC? On my hydroboost setup the front (smaller) MC reservoir is for the rear brake system like Blue Ox said.
coachdtierney54
US
C30
Yes that leads into the cab and connects to trailer brake controller.
coachdtierney54
US
C30
I have no clue what is going on with it
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Okay, so a brake controller should be a switch. I don't think it has any bearing on the truck brakes unless it is leaking.
On my truck the larger reservoir is in the front, but the smaller one is still for the rear brakes. Calipers have much larger displacement and need a bigger reservoir.
coachdtierney54
US
C30
Found the leak. What is this?
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Load sensing proportioning valve. Good luck finding a replacement. Most folks, and apparently GM say to eliminate it. But I had severe rear lockup problems on my 'burb without that valve. YMMV. Although I would replace that rotten lower pipe before I condemned the valve.
coachdtierney54
US
C30
Lot of rust for a southern truck... How did you bypass yours? I thought about getting an adjustable valve from Jegs.
Wes P
Wes
Posting in all LSPV-related threads for reference:
LSPV delete on '85 C20 increased braking performance.
Basic procedure:
- Remove valve, post-LSPV hard line, hose, axle bracket
- Measure, measure again, cut, drill, tap, weld stop nut on bracket (or add a screw)
- Release axle hard line from clips
- Install bracket, brake hose (180 flip), zip ties
- Bleed brakes
Parts: 2 zip ties.
Materials: brake fluid
Time: 4 hours, leisurely, without experience, being careful.
Note: Be gentle with hard lines. Plug the hard line after disconnecting. Don't empty the master cylinder.
Pilotanpia
