Brake pedal goes to floor
chevyfs
michigan
ray
Chevy C10 Rwd P/U
4.3liter V6
The brakes only seem to work towards the end of the travel, in order to stop i usually have to fully depress the pedal to the floor. The pedal is also really soft with little resistance with the truck running. i'm not quite the smartest when it comes to brakes n the only thing i can think of trying is bleeding the brakes, so im just wondering what yall are thinking
R Carnella
Long island
Rich
Suburban V2500
Topping off the master cylinder and having someone help to bleed the brakes is a great place to start. Air in the system can cause you're symptoms.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Bleeding is a good idea, but my instant thought was bad master cylinder.
fast 99
Spokane, Washington
If the master is full, it happened "overnight" and no work was preformed agree on the master.
chevyfs
michigan
ray
Chevy C10 Rwd P/U
4.3liter V6
The master holds fluid and is always full, They have gotten worse with time it seems though. The brake booster line had duct tape on it but it didn't look like it was doing much so i removed it, after that they seemed worse lmao, could a leaking brake booster cause those same symptoms by chance?
350 w/203
2 person job. Have someone hold down the brake while you check out the brake hoses for swelling. Bleeding them is a good idea. What does the brake fluid look like? If it's brown I'd flush the entire system.
chevyfs
michigan
ray
Chevy C10 Rwd P/U
4.3liter V6
It is pretty dark almost looks like oil.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
The way that I know to test a brake booster is to pump the brakes with the engine off, then while holding the brakes, start it up. The pedal should fall some small distance and then hold there.
If it does, the booster is in theory good, and in that example, the MC, too.
If your booster was not working you would have manual brakes and braking effort would be shall we say pronounced ? :Big Laugh:
Try flushing as per @Snoots which in essence also means bleeding as per @R Carnella and see if the pedal firms up.
fast 99
Spokane, Washington
A bad booster won't cause a low pedal, just the opposite. The pedal will be hard and high. OP says it's going to the floor. From the description, replace the master. Yes, flush the old fluid out. Be sure and check the adjustment of the drum brakes.
As a side note, brake fluid should be flushed/replaced every 2 years. I use a turkey baster and suck the fluid out of the master every spring. It doesn't get all of it out but is very easy.
MTBR12
