Brake lights
83chevyk10
Rising Sun, MD
Caleb
350 SBC
Not an electrician. All lights including running lights and turn signals work, but no brake lights. What am i looking for? Im sure its a simple fix. Thanks
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Have you checked the fuse and the brake switch? It’s likely the brake switch, and that only takes a second to replace.
chengny
Check for power into the brake switch (orange hot all the time from the battery). Depress the brake pedal and confirm power out of the switch on the white lead.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Since you have them signals your grounds should be good then btw, just to rule things out
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Try disconnecting the wiring plug for the turn signal switch and reconnecting it.
Worked on mine.
Long black plug on the right side of the column JIC ...
:D
I had the same issue.
Tdabney
