brake lights
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
i have no brake, turn signal or hazard lights. the running lights and front turn signals work. any ideas where to look ? its a 87 r10 step side. Thanks
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Pull out the rear lens housing(s) and check the ground wire(s). They usually get rusted/corroded up and make the back lights dead.
towman
harrisburg pa
jay
v10
if has a trailer harness on it check that also, a lot of time they were butchered when put in and will cause major headaches
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
if all that fails check fuses.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
the fuses are good. no trailer harness. ill check the ground tomorrow. thanks
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
should have also said the running lites and back up lites work
Might sound a bit dumb, but check the bulbs. Maybe the brighter filaments have burned out.
Turn signal switch ?
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
the bulbs are good.the front and dash signals work
crazy4offroad
K-10
350/SM465/NP205
Could be a break in a wire along the way towards the back. If you have a tester, turn on the hazard lights and check the socket for signal. If none step back to the wires about a foot upstream and check again. (Tester might have a probe you can use to pierce the wire enough to check it.)
Isn't there a plug in the harness near the cab that runs to the rear lights? I'd check that too with a test light.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
ill be looking for that tomorrow
dabsRus420
