Brake Light Switch...
quadracerx
Graham, WA. USA
Steve
My flatbed had an aftermarket Cruise Control that has a two wire connection and a vaccum port. None of the factory GM Brake Light Switches have a vaccum port.
Sooo, Im goint to replace the existing switch with a GM Replacement 4 wire Brake Light Switch for Cruise Control and block of the vaccum port, since the Cruise Control didnt work anyway and I have the 4 wire switch already.
My question is, which of the 2 sets of 2 wire connections should I connect the wires to? Or does it matter?
Thanks for bearing with me....
Steve
Snoots
Roger
Jimmy Sierra
350 w/203
Use a meter. Set it on 'OHMS'. Touch any 2 of the terminals. When you find 2 that cause the meter to go to '0', press the switch. If the meter goes to infinite, those are the 2 terminals you want. Repeat until you get it.
Norm310
