RLC2020
- Oct 13, 2020
- Malabar FL
- Ross
- Suburban C20
- 6.2L Diesel
Hi all,
Issue is when at a stoplight for an extended period of time, the pedal will slowly inch down while holding it and the brake light will come on if stopped long enough. Once I let off the brakes they are fine again. The brakes all seem to work great and the truck stops just fine even towing my 5,000lb boat. I had to do a panic stop the other day and I was actually impressed with how quick it stopped. Any suggestions? This is my daily so I don't want to tear it all apart without having replacement parts ahead of time if possible.
Brake fluid level in the master cylinder is full, clean and has not moved. I don't see any wet spots on the back of the drums either so I don't think I have a leak anywhere.
