PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- 84,79,77,76,70,48
- Suburban k10, bonanza k10, k30, k20, c10, gmc 1/2ton
- 350, 350, 350, 350, 350, 350
80's k10. From my research all the lines after the proportioning valve should be 3/16 correct? Are all fittings to the wheels and brake hoses 3/8-24? As well as into the proportioning valve? All are 45 degree double inverted flare?
Just for future info one of the lines to the factory prop from the master is 1/4 inch correct? And some weird flare nut size?
Just looking for a for sure answer, I'm swapping to an aftermarket master and prop valve, so I'm redoing all my hard lines. Couldn't find a definitive to all my questions, haven't done a full hardline replacement. Just need a spec sheet for all of the hardlines.
