eskimomann209
- Jan 9, 2019
- Modesto
- Marcus
- C10
Was swapped out yesterday. My 1973 c10 got a fresh booster yesterday.
I have a verrrry high pedal and big feet. The pedal is definitely higher than it was before and has quite a bit of free play before actuating the brakes.
The booster to pedal rod... if this is “lengthened” does this lower the pedal/ free play?
and the booster to master piston... this just adjusted When the pedal transfers to the master? Extending it out toward the master causes quicker engagement?
Just want to be sure I am armed with the proper adjustment theories.
Booster was replaced due to a slight whistling sound emitting from it while driving.
Please and thank you gents.
