Booster relocation
nickdiehl
conroe
nick
can any one tell me if and how i can relocate the booster and master cylinder on 84 k10 or a booster that is smaller that i can use im trying to run headers out the hood and the master cylinder is in the way thanks
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Non power brake master cylinder is smaller. Well, not smaller, just doesn't have the booster. Not sure if you can run disc brakes without a booster though.
MadOgre
NA
NA
NA
NA
NA
find a hydro boost setup and put it on yours
highdesertrange
kalifornia
mike
k30
mad is right a hydro gives you a little more room. highdesertranger
nickdiehl
conroe
nick
Thanks guys I thot about hydroboost I'm not sure how to install it tho. What about the chase bays universal booster eliminater any one familiar with it? Looks like a good option
What's the purpose of the truck? Are the power brakes important? I'd consider brake booster delete if the headers thru the hood are that important.
With headers thru the hood, I'll make an ass out of us and suggest the truck is for off-road use only. You don't need power brakes for off-road use IMO.
I suggest that cuz even the hydroboost unit is quite pricey plus a power steering tank update for the 3rd line.
MadOgre
NA
NA
NA
NA
NA
Ya Junk yard special for sure.
highdesertrange
kalifornia
mike
k30
you don't have to change the ps tank if you put a hydroboost on. you can "t" the return line. although the tanks are not hard to find. highdesertranger
MadOgre
NA
NA
NA
NA
NA
Its a direct install in place of vacuum booster. Just be safe and grab everything from donor truck. master, lines and power steering pump, and brackets. Im not sure but I do believe they use different pumps from hydro to non hydro. Both can be interchanged in the reservoir housing. Its always nice to have the proper stuff for the application being used. like a reservoir with 2 return lines. Just looks right.
OSReaper
