Blower motor high clicks on and off
dkraven
Portland, OR
c25 Sierra Grande
Since getting the truck with a nonworking blower I’ve fired the parts cannon at it, multiple volleys. The system has a new blower motor, with all the ground connections cleaned because that was a problem. Also new relay, and new switch in the cab. Was thrilled when I fired it up and all 4 levels of the blower functioned. And then there was a click and high switched to medium 2. Moved the switch down and up and high came back on, and then clicked down to medium 2. And then clicked on a moment later. I would assume there’s something loose along the orange wire between the switch and the high speed relay but not really sure how to go find it.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I had a similar thing. High would run fine for 1 minute or 45 minutes and anything in between then just randomly shut off completely. I could switch speeds and then right back to high and it would work again.
Brand new relay was bad. That may be your issue, but you could also have a short between high and 2nd speed.
350 w/203
Switch problem.
350 w/203
Hopefully as that's easier than tracing wire. What makes you say that though?
Had a similar problem years ago on my '73.
I very carefully took the switch apart, note carefully, cleaned the contacts, smeared the inside with di-electric grease and re-assembled.
That's been about 6 years ago and haven't had a problem since.
dkraven
Portland, OR
c25 Sierra Grande
Tried a new switch and it works like a charm. Good thing too because the temperature dropped and I needed the heat! Thanks for the help.
new73chevyjob
