84chevguy
- Dec 20, 2015
- Roy,washington
- Patrick
- K2500
I have an 84 gmc k2500 I bought it a year ago and the heater never worked. Fan does not kick on at all. I've bought and installed the following.
Relay
Blower motor
Resistor
I regrounded the relay to the alternator. For some reason every time I turn the key to the on position the fuse 25a keeps popping near the pedal. I looked around near the firewall to see if there was maybe an exposed wire of some kind and found nothing.
Before when I figured it was the relay I took the metal too off it and connected the two points together and the fan kicked on without the key being on I believe. I get power into my relay which is weird but no power coming out of my purple wire into the blower motor even with the new relay...... I'm stuck in a rut. If anyone could please help me out I would appreciate it a lot!!!
Relay
Blower motor
Resistor
