Anyone else confused by this exchange?
Terry asks a two part question:
1: Do the brake lights work? And 2: Is there a difference between front blinkers and rear blinkers? The rear blinkers and brake lights work on the same wires as I mentioned before. That will help diagnose if it is a wiring problem after the blinker switch.
The kid answers:
The switch moves but nothing happens. And the rears work fine but the fronts also turn on.
He seems to answer only one question. What does he mean by "the rears work fine but the fronts also turn on"
The front and rear what's? Maybe he's installed a set of those new "front end brake lights". O'Reilly's is selling them as a package deal with the blinker fluid - buy a set, and you get 50% off a gallon of BF.
This was the problem was originally described:
My blinkers don't work but every time the brakes are applied the lights come on?
That is SOP. When the brakes are applied, the brake & rear blinker lamps
should light up - because they are one in the same bulb. The brake lights are illuminated by default on both sides. They are only overridden when the hazard flashers or on the side that a directional signal is activated. But I'm preaching to the choir here - we all know that.
The only thing I can think of that he means is - that when the brake switch closes - not only do the common filaments for the brake/flashing lamps in the rear assemblies light up, but the directional filaments in the front parking light assemblies do so as well.
The power supplies from the brake light switch and the pulsed power from the two flashers (hazards and directionals) are well protected - by being inside the cab - and are kept isolated from each other up to and through the MFS. I don't mean to be insolent Mr. HRPC, but I checked the parts lists and wiring diagrams, and a rudimentary MFS was in use in 1980. It was just a directional switch really, but it did also control the function of the hazard lights, brake lights directionals and horn:
Anyway, it seems that there is a cross-feed situation somewhere between the two circuits - but on the load side of the switch. It would be a stretch to imagine it existing on the line side because of the protected in-cab conditions or that the switch itself had failed. I know they do fail, but usually not in such a manner that it would allow the brake light power lead to come in contact with the directional circuit.
It's probably time to break out the Fluke meter and start ringing out the cable run from the rear rear lighting assemblies to the firewall transit block. I'm going with something simple that will jump right out at him - like the harness is pinched or melted by the exhaust system.
But, I have been wrong before - I think it was back in 1994-5.
