Blinker issues “SOLVED”
Kasey 1977 K10
Kasey
Hate to poach your thread but I saw that your inside blinker isn't working. I have a similar situation and am looking for guidance. All the exterior lights work as they should. I can also hear the left blinker but the light does not come on in the console. I have replaced the circuit, all bulb housings and all bulbs. It didn't work before I did all that and still doesn't. Any ideas?
Jppr26
Deer island
V20 custom deluxe
The side marker light wires were chewed off from a mouse or squirrel and has been replaced and works, I think the front and rear lights are switched individually along with the dash indicator light
Jppr26
Deer island
V20 custom deluxe
So far all my running lights work perfectly, my front right dose not blink all the other lights work as they should, the front right won’t even flash when I turn on the hazard lights
350 w/203
Are you absolutely certain that the bulb is NOT the culprit?
Jppr26
Deer island
V20 custom deluxe
Yes, it is a new bulb, and I even switched it with the one from the left side that works as it should and the left works fine with the new bulb, and the old
Jppr26
Deer island
V20 custom deluxe
I’m suspecting my multi switch in the column I pulled it out and was going to bench test it but I don’t know what wire is the common ground/hot, I guse I could just run through them all and what ever one is the most constant is the one I’m looking for, right?? I suck at this wiring thing
Jppr26
Deer island
V20 custom deluxe
So it turns out it was the blinker switch in the column, it went in easier than I thought it would, turns out the reassemble was a bit more of a pain, mainly when you realize you missed a piece, and then another, and have to take the column apart 2 extra times. But it all works as it should
Kasey 1977 K10
Kasey
Is this what fixed your dash blinker light? If so it looks like I need to do the same. Not too confident taking my column apart.
Jppr26
Deer island
V20 custom deluxe
It was kinda easy not much on the YouTube that I found, there is a turn signal switch video or two but nothing 100%. You will need a steering wheel puller, and a lock plate compressor, philips, few torques, and 3 different sockets to remove the column/dash mount, and steering wheel nut, both puller and compressor are less then $15 each and the switch cost me $50.
It probably took me about a hour to do it the 3 times and get my dash reinstalled most of the way. And I had to do it 3 times as well, I’m doing good at remembering where all the leftover parts go and taking the time to take **** apart again to put them back in
hatzie
k20
There are several videos using the T400 CK chassis... Very similar column to the one we have in the 84-91 CK & RV trucks.
Saginaw columns were put in lots of different vehicles from GM, AMC, and Chrysler. My 85 AMC Eagle wagon has a Saginaw column. The column I cabbaged out of a Concord for my first Eagle was a Saginaw unit. My stepbrother's AMC Jeep has one too.
I highly recommend getting a lock plate tool.
Heres a playlist using an 89 RV chassis with a tilt Saginaw as a victim. Not family/work friendly. This guy has some colorful things to say.
Here's a regular Saginaw with multifunction turn stalk.
F1r3truck
