rprentiss288
- Jun 25, 2014
- Detroit, MI
- Ryan
- K15
Need some help here, i'm stumped.
1978 K15 binds up turning right under braking.
Front calipers and rotors are in good shape.
Replaced this spring (no issues then)
-steering stabilizer
-tie rod (inner/outer)
-drag link
-body bushings
-sway bar bushings
-driver front axle u-joint
-wheel bearings
-warn locking hubs
-spindle bearings
-shocks
-upper/Lower ball joints
-(used) rear axle shafts
Just replaced 200 miles ago
-rear drums
-entire drum hardware
-rear brake cylinders
-parking brake cables
I took the drums off and the shoes have uneven wear on them. Is this because they're not adjusted correctly?
It did this before and I replaced passenger u-joint and it was fine. Drove for a while, started again, found the driver front lugs were loose, tightened them, fine. Now again. ONLY when turning right though. Leaf springs are sagging pretty bad (1" off bumpstop)
Any ideas?
-drag link
-body bushings
-sway bar bushings
-wheel bearings
-warn locking hubs
-spindle bearings
-shocks
-rear drums
Any ideas?
