Best Locker for 14Bolt FF in 85 K30
WyoK30
Wyominf
Ben
V1500 Suburban
Looking for input and pros and cons. I want to put a locker in my K30 14 B FF, and I dont know mutch about them other than to avoid the "GovBomb" Thanks in advance
So here's the deal on the Full Float carrier. It's a split carrier with spider gears inside it. Now if you have the Gov Bomb carrier now, then you're jacked and will have to swap out the whole carrier with an open diff.
With the open diff on a Full Floater 14b, as said, being a split carrier, you can open it up and replace it with a Detroit Locker which one of the bigger famous name brands. My point being, since it's a split carrier that you open up and replace the spiders, in this case, even the Detroit Locker works as a "lunchbox locker". I don't know that there is a bad lunchbox locker for a 14b full float axle since they are all just about the same whehter you get a Detroit Locker, a Lock Right, a Spartan locker or some Grizzly locker whatever it is. But there is several of them now days. I personally would just Google Locker for 14 bolt Full Float and then choose one based on price and reviews. Detroit Locker is good, and I think you'll pay more just for the name, but as said, due the FF carrier design, they are all about the same. I know for a fact Lock Right is made by Richmond Gear or their parent company and we always used Richmond Gear back in the race days cuz it was always good stuff at budger prices and street racing wasn't cheap. PowerTrax Lock Right is the name. Heres is an example of the Yukon Grizzly at Amazon for $415. https://www.amazon.com/dp/B0078UBMZM/ Link Included. PowerTrax LockRight at Rocky Road Outfitters for $411. Now make sure those are the correct ones for the correct axles and all, these are just examples, I didn't do any research. https://rocky-road.com/shop/gm-14-bolt-lockright-locker-1955/ Link Inluded.
If it's the correct one, here' the PowerTrax LockRight 1955-LR for $238 for the 14b 10.5in 30 spline axle. for $238 at Amazon. That should be the right one, but I guess you use the same cross bars that are currently in use with your spider gears if it's an open diff, since they do not seem to be included here. See if you read over an install guide or something to make sure it'll work, but $238 is a fantastic price to convert your 14B FF to a Locker. Comes with 2 year 100,000 mile warranty. https://www.amazon.com/dp/B003JBV9RK/ <<< Link Included
SquareRoot
I hated my Detroit locker so bad I gave it away and went to an open carrier until I can afford an ARB. I effed around and found out. Disclaimer: I only hated it the 100% of the time I was on pavement. Off road, it was decent. Would have been great if I had an auto trans. With manuals, not so much.
I know I've hated on the GovLoc a bunch in the past, but it's really not a bad unit in the 14ff.
Did you actually give it away? I would have been a happy bottom-feeder in that case :rofl:
I have a Yukon Grizzly locker in mine. Like bucket said, you really can't go wrong with any of them. I drive mine a lot on the street, gravel logging roads, and some mild offroading and the Yukon has been pretty good. I don't get a ratcheting noise at all, but I do get a bit of wheel skidding in very tight turns on pavement. It's not a big deal at all. I only got the yukon because someone had a brand new in-box unit with a richmond rebuild kit available locally for $200, but I don't have any regrets about installing it.
nvrenuf
Mobile, Al.
I ran a Detroit Locker in my old K10 and later moved it to my crew cab, I loved it. I'd buy another one.
SquareRoot
CL for $50. A guy called me 15 minutes later and wanted it so bad he drove 150 miles from Phoenix that night after work to get it. I was like damn, I should have asked $55. lol
Damn! I can't say that guy stole it from you, because you knew what it was and just wanted it gone, lol.
vr1967
Virgil
k1500
6.2L turbo
The Gov Loc for 14b ff is not a bad unit. Like someone mentioned above, I did not care for either the Lock Right or Detriot Locker’s manners on the street. So much so, I replaced with a new Gov Loc unit. The money I had trying the 2 others was the same as the new Gov Loc from Eaton
yellow eyed Andi
