Bell-housing Zerk Fitting
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
There's this zerk fitting on the bellhousing:
What is it supposed to grease? How do I know how much to add?
Thanks.
Georgeb
Wisconsin
George
K10 Burb Z71
That should be for the pivot ball the clutch fork rides on. It should only take 2 or 3 pumps of grease. You can see it if you pull the fork boot off.
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
By "it" do you mean the grease coming out? Or the boot? I can't find a boot...
This is what I'm looking at: (ignore loose slave bolts)
I pumped a bit of grease in and it sounded like something was moving with each pump...
Didn't really notice a difference in pedal feel after the grease was added.
Georgeb
Wisconsin
George
K10 Burb Z71
"It" refers to the pivot ball and the grease when there is enough. The boot I am refering to is the rubber part in the bell housing hole that the clutch fork pokes through.
brad083
