Bed mount winch
Camar068
10 yrs Air Force
Bed winch mount frame thoughts. No welding to the vehicle. Bolt to the 2 vertical square things on the front (sorry don't know what they are called), and bolt angled bars to bed bolts.
Only welding is on the winch frame itself. Can be removed. The tubing is 3/8" thick.
Main use would be to pull up deer from a decent grade utilizing a deer sled and good rope (~150' drag).
Thoughts? Better image in a minute, sorry.
Camar068
10 yrs Air Force
full
If you welded studs (or hood pins) to the tops of the bed bolts, you could have your winch bracket literally drop in place using the bed bolts and stake pockets. You would just have those studs/pins to contend with when you don't have the winch in place.
Camar068
10 yrs Air Force
you got me thinking about the floor bolts. Maybe just weld some thicker nuts to the front four and have a plate with the winch already mounted to it. Like you said, have to deal with the nuts sticking up.
Or even 4 nutserts on the lower ribs of the bed. Leave the bolts in when not in use with anti-seize. Would require drilling holes, but for a flush bed I could prolly deal with it.
Camar068
10 yrs Air Force
Changed the mount style. Few more questions to follow.
Camar068
10 yrs Air Force
So now I'd like to put a big boat trailer roller on the tailgate. Easy enough, rectangle bracket with roller sticking above the tailgate.
The 2 holes circled close to to top of the tailgate, is there anything mechanical for the tailgate release there inside?
If not, I'll sacrifice the lower trim screws circled and put nutserts in all 4 circled locations. This way when it's not in place, the filler bolt heads will be below the sliding surface.
Camar068
10 yrs Air Force
Roller of this sort:
snowman4evr
