Bed Deck Bolt Spacers
Ronno6
South Mississippi
Ron
The OEM deck had steel spacers thru the wood deck at the mounting bolts.
The holes I bored in my white oak bed boards are off location a tad, enough to prevent me from installing those spacers.
I believe that those spacers insure a good solid fastening of the bed cross braces to the chassis, without clamping
down on the deck boards.
Can I live without those spacers, or do I need to cut thru the sidewall in order to allow for the lack of clearence at the point of
interference with the bolt??
That would still allow a solid metal to metal fastening.
But, are they necessary?
MarineOne
Western New York
You should be just fine. Those spacers are there mostly to not allow compression with heavy loads
Mine has homemade wood planks and there's no spacers in use. It has held up great over the years without them.
GorillaHumper
