Personally I am NOT a fan of any external greasing methods. If you are forcing NEW grease in to the hub then the old grease has to go somewhere, which is out the back of the hub past the seal. Keep in mind the seal has 2 jobs 1 to keep grease inside the hub, and 2 to keep moisture and contaminates OUT of the hub. If your forse grease past the seal you may aswell remove the seal as it will NOT work properly again.
Another problem I have with them is the wasted grease inside the hub. Before you can force the old grease out of the bearing cages you have to fill the space between the cap-outer bearing, then from the outer to the inner bearing, and then from the inner bearing to the seal, which is ALOT of wasted grease.
IMHO you can NOT beat repacking the bearings by hand. Repacking by hand will allow you to visually INSPECT the bearings, races AND the spindles.....
