Barn door to tailgate conversion
HankerCarl
Chippewa Falls,WI
Carl
C1500
Has any one on here ever converted from barn doors to a tailgate on a suburban? I have really been considering changing. Never was a real big fan of rear doors but saw her and decided to save her from the auction house. Any help would be appreciated.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Great save!!! There is a guy on her that converted a tailgate blazer to barn doors but im not sure who
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Why? Tailgates suck.
At least mine did. Rattled all the time, window was usually a problem etc. 9/10 I'd have preferred the doors.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Welcome to the site!
I have seen a few people do it the other way around but I've never seen someone get rid of those god awful rear doors in favor of a tailgate, someone here even ruined a perfectly good k5 blazer by making it a hard top with barn doors. I say go for it, definitely can be done and would probably be easier than doing it the other way around. Would be a cool mod IMO, hope to see you tackle it!
Why? Why not? The tailgate looks sleeker than those ambulance doors and is more useful if you plan to use the truck as an actual truck rather than a van. IMO if you want rear doors just go buy one of those 4wd G20 vans.
And if it rattles or the window has trouble going up or down it probably just needs a little maintenance. When I changed out the dry hard rubber seals the window went up and down so much better, there is also a slider on the regulator that needs to be cleaned and lubed. For rattles you may have to adjust the strikers the same as you would on your side doors if they rattle. Not a big task really. It's all a matter of personal preference and what you like, but I wouldn't knock the tailgate just because you had one that was in bad shape
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
My gmt 400 i prefered the tailgate over barn door. Better visibility
HankerCarl
Chippewa Falls,WI
Carl
C1500
Every square body that I’ve ever owned or been in with rear doors rattled so bad and needed constant adjustment. Ive never had as much noise from a tailgate.
HankerCarl
Chippewa Falls,WI
Carl
C1500
I have done some cosmetic upgrades to her. This is what I bought. I converted to all LED lighting including headlights. Removed the god awful aluminum running boards and removed everything smog related. Went with an edelbrock intake and carb. Upgraded to 18” wheels and tires. I also plan on a 4”/4.5” drop and a LS swap. Oh and don’t forget the tailgate conversion. Then ready for paint and body.
yevgenievich
Place
Name
Year
Model
Size
It is mostly already set up for a tailgate. The lower valance piece I believe is different. Otherwise most parts swap over.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
My brand new 88 I ordered with a tailgate. I couldn't imagine having the barn doors. The rear view while driving was perfect. The ability to have the window down while driving for more airflow was amazing until the exhaust fumes almost made you pass out. Then the power window had issues as it got older. Would go down but not back up or come back up canted. Or not work at all. Can't tell you the grief I experienced trying to get that POS working again. Drove that truck 245k miles.
Fast forward to my now new 86 with barn doors. Still can't imagine having them but you get what you get. Tried to figure out what I needed to do to put a tailgate in just like you but figured I would give the barn doors an honest chance to sway my thinking.
I have to say to date, I'm liking the barn doors more every day. There is zero rattle but I'm sure the new weatherstripping as something to do with that. They close really tight.
Everytime I put something in the back end of that thing my back thanks me for not having to bend over that damn tailgate.
The post smack in the middle of the rearview is kind of a pain but that's what you have outside mirrors for and I find pretty easy to adjust to. Towing anything makes the windshield rearview mirror pretty much useless anyway.
It makes me think about the morons that bought a 63 split window Vette and decided to take that center post out and put in a 64 rear window.....all because they couldn't see out the back. They're kicking themselves now for that major ******.
I get why you want to do it but I say give the barn doors a chance before doing anything radical. Just IMPO.
idahovette
Weiser Idaho
Perry
K20-K10
I have a split window Corvette and I hardly use the mirrors, everybody looks out for you!!! Also that's why cops have sirens, so you know to pull over or go faster.
I'm a dyed in the wool tailgate guy. I love my Burbs with tailgates and will always prefer them over barn doors. Just the ventilation alone makes it better.
A member here converted his Burb from barn doors to a tailgate. @Daveo91Burb I believe it was.
73c20jim
Tombstone, AZ
Tailgate guy here. Always had a place to work on ****. A place to put tools.
YMMV
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Yep, that was me and it most definitely can be done. Lots of work, though. Took me several months and I had a parts burb with TG. Interestingly, while these posts were being made I was camping with my burb and sleeping in the back. TG burbs are much nicer to sleep in than barn doors. I wired in an interior rocker switch for the window so I can roll it down from the back with the key off. (started to rain midway through the night so I just reached out and rolled up the window!) I also wired in a switch so I can turn the interior lights on from the back. TG burbs are also nice to sit on and use as tool platforms as previously mentioned. They also don't swing into the car next to you in the parking lot when you open them. Drawbacks include more rattles, window adjustments, motor difficulties, etc. But I love mine and would not go back.
Here's my build thread. Biggest issue by far is the tailpiece (part where the TG hinges mount to). After the early 80s GM made the diverge point between the two models much earlier on the assembly line . Barn door models are missing supports in the tailpiece for the TG - it will flex way too much from the weight of TG without any support. Tailpiece is replaceable, but it is a major bodywork operation. I modified mine in place instead. I used pressure treated wood as a support - just blocks of wood in between the flanges of a C-channel. Cheesy yes, but it works and it will last a long time. Alternatively one may be able to weld some vertical plates in as support, but I'm not a good welder and the access is horrible.
Here's another thread where I was planning the project - may be some useful info.
Good luck, PM me or tag me in this thread if you have any specific questions.
rlfdavin
