AVAILABLE: Pre-'81 Factory Tach complete cluster
mtbadbob
Montana
Bob
V20
I found a complete factory tach cluster out of a '77 or '78 Blazer in nice condition at my local honey hole. He's asking $125 for the complete cluster. Lmk if anyone is interested, I can go grab it!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Wondering if that would fit in my 79' c10 with minimal fuss ? I'd be interested if so
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Yes it will. You need to trace the printed circuit on your cluster and move a couple wires in the plug to match the new cluster. The tach has it's own separate plug that you can do with spade connectors, Pos. Neg. and tach signal.
The fuel gauge will work, but if the resistor on the back of your gauge is different than the blazer's that needs to be swapped. (factory resistors are different colors for different values)
Vbb199
Salisbury NC
Vince
I know in the past, I've had issues putting a truck cluster in a k5 without some dash frame trimming, so I didn't know if it was the other way around, as well
Sweet. I'll think on that one.
mtbadbob
Montana
Bob
V20
If you haven't already please grab it. I am interested.
Ok, is there anything else you might need to make it work? I could see what all that Blazer has, like tach filter??
tobiahr
Atascocita, Tx
Tobiah
Blazer 2wd
L59 5.3 swap
There shouldn't be anything else needed just the cluster. and I am not sure why but i am not getting notifications when this thread is updated
mtbadbob
Montana
Bob
V20
The gauges have nice color for being 45 years old! The oil press is a manual gauge
tobiahr
Atascocita, Tx
Tobiah
Blazer 2wd
L59 5.3 swap
Nice score! I'll take one for an '84 non-tach(or with to be honest) unleaded please. LOL
I should have a stock one w/o tach from a 81 with a working clock in the bottom left position.
Soundmound
North Central Washington
Dave
Scottsdale
I'd have a look. Seems rebuilding mine is tough with availability on some of the re-pop parts.
iandrake
