Audio unit and road noise
Camohurley
Joseph
C10 scottsdale
Also something I'm not understanding is the antenna cable supressor when plugged into the back of my radio it gets rid of alot off the noise but the radio is just extremely staticcy is that because it's interfering the signal from the fm transmitter?
Camohurley
Joseph
C10 scottsdale
Well....the relay didn't work either still clicking.
Camohurley
Joseph
C10 scottsdale
It seems like even with bypassing all factory wiring I still have the interference on two separate radios
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Where are the radio grounds going to? The original harness? Or grounded somewhere under the dash?
Try taking a jumper wire and ground the radio straight to the battery. Seems like the other accessories are backfeeding into it for some reason.
Is this a 12v or a 24v truck?
Camohurley
Joseph
C10 scottsdale
All grounds are into the metal dash. It's 12v.
Camohurley
Joseph
C10 scottsdale
With the ground for the radio and the 12v supressor straight to the battery no change.
Camohurley
Joseph
C10 scottsdale
Is it possible I just have two bad radios? Does anyone know where I can get a factory am only radio in working condition? (Or at least one that is fully analog wife doesn't wanna any digital screens)
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ok so your saying I should get a relay and wire it to my battery and to the radio and then run the original power wire from my radio unit to the relay to engage the relay correct?
Yes sir. 85 ground, 30 battery, 86 original radio 12v source 87 to radio.
Camohurley
Joseph
C10 scottsdale
I tried that out no luck. I connected the radio to my battery in my 2013 and no clicking so I don't think it's the radio. Did those trucks by chance have a ground wire that went to the fuse box? The wires in this thing are all jumbled and effed from the fire department and the owner before that was a farmer. Stuff has just been cut out and spliced in as needed. But it seems like the only other thing I can guess would be a short in the fuse box somewhere sending all electrical signals to the radio instead of to a proper ground
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Direct power from the battery should cut the rest out and 86 and 85 go to the coil in the relay 30 and 87 are direct once the relay is activated.
Camohurley
Joseph
C10 scottsdale
With the relay hooked up and all internal wireing bypassed it still has electronic feedback
Camohurley
Joseph
C10 scottsdale
I am so confused right now
Camohurley
Joseph
C10 scottsdale
Also with everything ran straight to the battery I still get the electric noise and when I turn on headlights it gets quieter. The other thing idk if I mentioned is the buzzer that says fasten seatbelt also comes thru the speaker upon ignition
Camohurley
Joseph
C10 scottsdale
One more thing guys I got my buddy's truck and plugged the radio in full with the antenna cable no issues prior to this and it did the same thing...could the port you plug the antenna into go bad on these?
Camohurley
Joseph
C10 scottsdale
Is there supposed to be a second wire here? Also sorry for all the posts just losing my mind
amoretta
