Backfoot100
- Aug 18, 2017
- Florida
- Eddie
- C1500 Suburban
- Carbed 350
I just put these step bars on and wanted to share my experiences, good and bad. Let me first note that I’m not a huge fan of running boards, steps or step bars. They serve a functional purpose under certain conditions but I still prefer my vehicles without. That said, on my original FWD 88 Sub, I put running boards on 30 years ago to help my vertically challenged wife and kids get in/out of it. Now I need the same assistance for my wife and grandkids with my 86 Sub due to the taller tires/wheels I have on it even though it’s only RWD.
As most of you know, the options are pretty limited for these trucks. Running boards are still available from LMC but I went that route 30 years ago. Then again, LMC isn’t exactly cheap. I thought I'd try a step bar this time and the only one I could find was from Aries. Model 204039-2. Polished stainless 3” round double pad step bars specifically designed for ALL Suburban’s, 73-91 that includes all mounting brackets and hardware. Touted as being bolt-on, no drill installation. I seem to remember that same claim 30 years ago with the running boards which couldn’t have been further from the truth. So, between my penchant for perfection and these previously false claims, I’m expecting the worse possible scenario.
I ordered the steps from Amazon for $230 delivered. They arrived several days later with the box partially opened up. I’m sure just due to trying to handle the oversize box. The UPS driver wanted me to inspect them before accepting delivery. I did and they were actually packaged fairly well. The brackets, hardware and bars all intact and undamaged. The only thing I couldn’t find were the installation instructions. Easily fixed by going online and printing them out.
The installation is designed to remove the front body mount bolt and install the front step bar bracket right on the body mount and reinstall the bolt. There’s a small support bracket that then attaches from the bracket to the frame itself purely for more strength. Pretty simple actually.
The rear mount is designed to mount on the front hanger of the leaf spring. You have to remove the leaf spring mounting nut (not the bolt itself, just the nut), slip the new step bar bracket over the bolt threads and put the nut back on. Then another support bracket runs from that hanger bracket to a crossover frame between the two frame rails. Again, purely for strength.
I soaked all appropriate bolts, nuts and mounts in penetrating oil numerous times for a week to prepare for the onslaught. The very first problem I run into is I need a special wrench to be able to take that nut off the leaf spring bolt. The nut is on the inboard side of the frame mount and only accessible from the top. Not easy to get to so I had to make a wrench that fit. I didn’t have an extra 7/8” wrench in my arsenal so I had to go buy one just to cut it apart.
That problem solved, I start dissecting the front body mount and the rear leaf spring mount. Both were completely effortless. Maybe just my rig being pretty rust free or the soaking of penetrating oil for a week or both….who knows. They came apart easily.
I start installing the front step bar mount. At this point I realize that the instructions are pretty vague and the illustrations are less then optimum but I think I get it figured out. The small support bracket that attaches the mount to the frame just happened to fit perfectly into a factory hole drilled in the frame. Ok...maybe this thing will work out after all.
The rear mounts are a different story. The rear hanger mount goes over the leaf spring bolt. Then a support brace attaches the hanger mount to the frame cross member. I just can’t figure out how it attaches without drilling a hole in that cross member. Then to add insult to injury, the muffler is in the way to drill the hole. After looking at all possible options over a couple hour period, I realize that there’s just no way to do it without moving the muffler and drilling a hole. I remove a clamp for the muffler and pry it enough out of the way to get a hole drilled but it isn’t easy. I get the support bar mounted to the frame and the leaf spring hanger mount. Mission accomplished.
