Arduino powered fuel injector tester.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
2.5% is a problem? I'd pee myself if I could get everything within 2.5%. Heck, I'd sell that stuff as blueprinted.
Rustybucket73
SF Bay Area
'73
C10 Stepside
5.3 LS
Honestly, its probably fine.
But since it doesn't cost me anything to flow them, I'll try and get it a bit closer. I can always sell a close set of 4 to the honda guys since they're starting to use the decapped injectors now, and use that cash to get some more injectors.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
So two of the 8.00 pumps were able to maintain pressure with decapps? Sweet!
Jrgunn5150
Ionia Mi
J.R.
6.slow
I finished the static portion of mine, just never followed up here apparently, code is in the description
73c20jim
Tombstone, AZ
Who besides me has no ******' clue what they are talking about????
Jrgunn5150
Ionia Mi
J.R.
6.slow
I'll CLiffs notes it for you. I'm not trying to be patronizing BTW.
Turbo engines need larger injectors.
Larger injectors are expensive.
Cutting the restrictor/spray cap off a stock LS truck injector roughly quadruples it's output for free, from 24 to 80-ish lbs/hr.
It's also wildly inaccurate, so they need to be tested, a set of 8 can have a variance of over 10%, or flow at right angles or something, thusly hydrolocking your fancy turbo LS engine.
Companies will test them for you, for roughly 75 a set, since you need to test at least 2 set's to get a matched set, it get's costly fast.
By spraying them into graduated cylinders, you can see the flow and pattern for yourself.
By using an Arduino, (a cheap little computer, 30 bucks), you can precisely time how long they spray for, rather than using a sundial or some other guestimation.
By knowing exactly how much they flow for a set time, boom, now you save yourself, or make yourself, 75 a set.
83SCLB
