WFO
- Jan 6, 2017
- Texas Panhandle
- Dan
- K20
I'd be afraid to use Flex Seal, or anything else "As Seen on TV".
Yep a 73 is the same construction as the 73-80 series and the 81-87 models are basically the same design, cowl area is just a bit different die to the sperate hood and cowl area.Are 73 K10 notorious for this too? Rest of truck is pretty much rusted bad in the wheel well areas and right where front fenders meet the cab in the corners at the very bottom. I doubt if water collection there anymore. Truck is used for my winter beater and bought it that way. Rest of truck seems dry but only drive it this winter and just got it after Christmas this year and drove it a few times because of snow. So I should look at it too or just don't worry about it because of how bad the rust is anyway? Thanks
Look at it. I am sure you have some water getting through somewhere.
Looks familiarHad the same feature on my 77k10. Lots cutting, grinding and welding to fix it.
GM used seam sealer on this area but with time the sealer dries out, cracks, and begins to let water into the seam between the two sheets of metal.
Is that what the factory sealer looks like? If that's the case mine had already been re sealed at some point. I had big floppy gobs out of like a caulk gun tube type. I was thinking GM brush the sealer on. The stuff I reapplied was out of a tube as well. AC Delco medium sealer.On my 82, they did a terrible job with the seam sealer in some areas, allowing water to drip down behind the fuse panel. That eventually caused rust to develop on the fuse connectors, and rusted out the bottom of the kick panels. It's fixed now, but all that trouble because of some GM assembly guy who didn't use enough seam sealer in some areas.
