Anyone running Wilwood clutch master
sqhead
Mexico
Roller
custom k10
I’ve got sm465 and 12” McLeod clutch. Looking to replace the old clutch master and slave. Wilwood recommended the 3/4” bore master. From what I’ve read the stock master bore is 11/16”. Would there be that much if a difference and what size slave would I need? Thanks
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Run what wilwood suggests. They spent the money on research and development. All you're doing is moving a clutch.
SquareRoot
Why not keep it simple and use OEM replacement parts? I got the master, slave and hose from Rockauto. Price was pretty cheap actually and it's worked flawless for 2+ years. What year is your truck? Is this a transplant?
koolbrezz
