Anybody know where these go
Wallace6
Wyoming
Ray
Suburban
I have worked on a fee and I have no idea and thanks
Wallace6
Wyoming
Ray
Suburban
Also I don't need egr but it is there, manifold vacuum vs carb?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
What exactly are you trying to figure out? I see your jack, your heater box, and some wires and stuff. If you want to know about specific wires or hoses, please point to/circle them in the pictures, or at the very least describe what we're looking at here. The pictures don't even look like the same truck, the ones with the jack pictured, some of them have wires/ hoses in the pics that aren't present in some of the other pictures. I'd be more than happy to help, but I'm honestly not sure what you're even talking about.
Rickf
Grafton NH
1974, 1954 & a 1937
Is there a sensor on the radiator, passenger side about 1/3rd way down the tank?
Wallace6
Wyoming
Ray
Suburban
I will try and take better pics but by the jack there is a huge harness by the brake booster,same side there is the single plug wrapped up. Heater box side there is one wrapped up by the box.
I will get better pics just wondering if anyone has any ideas before I head there and thanks
BurbanPena
Idaho
V1500
that bigger 6 pin connector is the harness for your cruise control actuator
ill double check the wire diagram but I believe that green wire is for the abs
What carb,what engine, what year truck are you running? That would help with correct egr routing. Generic would be ported vacuum to a TVS to the EGR valve. More generic would be ported vacuum to EGR valve.
Wallace6
Wyoming
Ray
Suburban
I am not entirely sure, it's an 87 suburban, originally a 6.2 and at some swapped to a 350, guessing definitely has a q-jet, when I get back I will definitely take better pictures.
Thanks
Wallace6
Wyoming
Ray
Suburban
Wallace6
Wyoming
Ray
Suburban
Wallace6
Wyoming
Ray
Suburban
These all connect to a big harness that into the dash by the fuse box
Wallace6
Wyoming
Ray
Suburban
I'm guessing the vacuum line was for the cruise control.
Thanks
Drauka99
Northwest Florida, USA
C-10
6.0 LQ4
That looped up bundle of wires looked like the knock sensor connector that was on my 81, 305 V8. mine was just above the oil pan on the block on the passenger side.
Rickf
Grafton NH
1974, 1954 & a 1937
There is a hint on post #4, you have some extra 6.2 diesel wires floating around.
F1r3truck
