Any explicit help on removing AC components and keeping heat?
projo198
Lawson MO
James
I've been trying to get a solid answer online and have had no luck.
My '78 K10 came to me with the outer heater box completely tore off. The only thing still there was the blower motor and housing.
I want to run heat only, no interest in restoring the AC (if it ever existed). The controls in the cab do show AC selections so I am guessing at one time it had it.
I have seen aftermarket "AC delete" boxes which appear to just connect the blower motor with the large square door in the firewall. I am in the process of fabbing my own to save money.
Is this job literally that simple? Does it require any modifications inside the cab?
Pic of my firewall. Any help/advice would be appreciated!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
That’s all that’s needed.
Technically, the air comes from the cowl area, goes down to the blower motor, the motor forces air thru the rectangular box, and then the various doors direct air thru the heater core, and to the various vents/outlets.
You will still need the vacuum line and vacuum storage ball to be able to control the function. Keep the heater control valve in the heater hose, whenever the temp is selected to full cold the water flow the heater core is blocked. Might keep things a little cooler in the cab.
projo198
Lawson MO
James
Thanks much for the info!
Rustisbest
Super Access Member
Athens, TN
You'll need a spot for the blower motor resistor too unless you just wire it on/off. Everything else can remain as is as already stated
5280k20
