Aluminum wheel deoxidizer spray
78C10BigTen
pennsylvannia
C10 BIG TEN
Not coated perfect. Then this is what i did at my detail shop.
1. Get some aluminum trailer cleaner acid spray you mix with water. Mix in spray bottle.
2. Wash the rims with a srub brush(plastic not metal) or pressure washer. Rinse
3. Spray on the trailer cleaner(acid water mix) and wait for it to turn white and foamy. Then rinse with water and repeat if necessary. They will turn kinda white looking when really cleaned with the acid mix.
4. Now get on it with the mother's aluminum polish. Those bastards will come out really nice.
Used to charge $100 for that service and did a lot of them.
Trailer cleaner like no income meth dealer or like 53' haulin ass pullin what you rely on trailer??,
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Like aluminum boat trailer. Aluminum cleaner of any sort will work. I can't remember the name of the acid but, you mix it with water.
Texbrite.com is where I used to buy it but, I think you can get it at tractor supply or even Wal-Mart.
Craig 85
Nashville, TN
454/TH-400/NP205
A trick I learned from a trucker with regards to Mother's type aluminum polish. To remove the black residue quickly sprinkle Corn starch on it then wipe it.
jimlayhee
