Alt putting out 17.4 volts. NOT GOOD right?
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
The red wire behind alternator is getting so hot it's melting. When I check voltage at battery it's only at 14.2 volts while it's running. But red wire at alternator is high. Is my alternator bad? How do I diagnose this alternator. It's from a 1992 trans am. FEAD.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
It's the red wire from the battery , to rear of alternator, not the 2 wire plug-in on top of alternator. Got so hot connector came off
The battery is brand new, so i know its not that
Tonimus
Phoenix
Tony
C10 Suburban
Not good at all. Regulator is toast. Probably reading that 14.2 at the battery due to resistance from all that heat. Throw a new alternator at it and check for other crusties.
If you're feeling froggy, you could wing a new rectifier and regulator at it.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Are you saying to just buy a rectifier and regulator and replace them inside alt? No special tools needed? Thanks
cowpoke
Poland
Tony
k20
you might wanna check the price of a new/refurbished unit. I'm all for fixing old stuff instead of replacing it, but sometimes, it's just way easier and quicker to get a new part and just chuck it in.
McLovin21
