The starter had three wires on the large terminal: Positive battery, red to firewall junction, and a light colored wire that was chopped off, live, not hooked to anything, and purple solenoid wire to circuit 6 on bulkhead. On the alternator the batt terminal, and pigtail red wires are spliced together. With my test lead hooked to the splice I get continuity at alternator pigtail, batt terminal, 2J, and 2E terminals. Brown went to 25 on the bulkhead as it should. Then there is the pigtail connection tied into the blue wire on the oil pressure switch connector which ends up at 931 on bulkhead. No oil pressure switch though. Pink to distributor(3), green to temp sender(35), tan to oil sender(31), a green wire to the choke heater. I haven't had time to trace where that wire goes yet. Somehow everything worked in this configuration, not the greatest, but it did work. With the new harness, the truck seems to run better, and the alternator seems to be charging better. 14.50 volts to battery. Gauge stays 1/8 inch above 13, like it used too even with the blower on high before it was stolen, rather than right on 13 when I got it back and on the road again. Just need to power 2J, and I'll be set.
