All 4 headlights went out at once
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Pull the flooring cover up in the corner, the dimples are there for the floor mounted switch, if the mat/carpet is original the hole for the switch is cut in it. The plug for the steering colum switch will plug into the floor mounted switch, if you cut the little latch off of it. need to add just a little wire to all three to reach. Not saying the floor mounted switch is better, but it ain't plastic, and alot easier to change next time. Will say the floor mounted switch is cooler. If an Aggie or coonass steals it, they won't wreck it getting their feet tangled up in the steering wheel trying to dim the head lights.... damn, I'm old.
nolv4ho
SW WA
Luke
350 tbi
Yeah it's on the column. I bought a new switch and decided after looking how tight it was just to unplug the old one and plug the new one in without removing it, to see if that would fix my problem, as I didn't have much faith that the dimmer was the issue. And no, it did not fix the issue. Atleast I was able to return it then.
Burbinator86
