SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
With summer coming I thought this might be a topic of interest.
So the mission of this thread is for folks talk about the methods they like to use for finding refrigerant leaks in A/C systems. Since 90% are running R134A, I'd like us to mainly focus on that, but most leak checking procedures I know about will work for R134A or R12. I'm hoping that folks will share their methods and also learn from this thread.
So personally I find that finding refrigerant leaks is a pain in the butt. I generally enjoy doing A/C work as most repairs are generally not that hard, but leak checking sucks IMO. The three methods I've uses are the "sniffer" style leak detectors and die. They both suck. The third method being soap and water method.
Lets talk about the sniffers first. All the ones I have used all seem to be prone to giving false positive leak results. Suppose you get a vehicle in your shop, or a personal vehicle and the A/C is flat. So you recharge the system, turn the sniffer on and run it along lines, by the compressor seals, next to the condenser, down the lines and finally in the vents in the car in effort to get it to go off indicating a leak. I use to always have trouble with it going off for no reason, giving false positive results. So much so that I don't use a snuff anymore. Pretty much ever. My newest one is probably 20 years old, perhaps there are better units out there today.
Die. So the principle of the die is that you inject it into the system. The die does not mix with the refrigerant, but it mixes with the oil in the A/C system. Some time later after some of the refrigerant has leaked out you'd shine a black light over the A/C components preferably in a darkened shop hoping to see the UV light die glow at the leak source. The problem is most of the A/C oil is in the compressor, with smaller amounts hanging around in the condenser, evaporator and accumulator. The refrigerant because it is in the system and under pressure does tend to pick up some of the oil, and thereby some the die and carries it around the system. So there is some hope that oil will seep at the leak point and you'd be able to see it that way. I've been able to diagnose a few evaporator leaks by shinning a black light on the condensation water or the housing drain. Sometimes die is really great at finding a leak other times it really sucks, it just depends on whether or not a little bit of oil is getting out with the refrigerant. I really do find that looking for the leak with die and a black light is best done in a shop with most of the lights turned off so it's a big dark or outside after dark.
Soap and water. Just like you'd expect this method involves a spray bottle with a soapy water mixture in it. Spray the soapy water on all the connections and components you can see and look for bubbles, much the same way you might do looking for a leak in a tire. The big downfall to the soapy water method is that it will only work on components you can access, so no way to check the evaporator with soap and water.
What do you guys think? Got questions, ask then. Got tips or another method to share, please do so.
