And here are the pics.
Here's what you get from "Classic Parts", p/n 91-450 for '73 - '79 @ $34.95. It's fairly well made. The paint is correct although it's not painted blue on the back, it's not painted at all. The needle is a rubber plastic, and it's got a good spring. All the holes are in the correct position, and it's got a good type of cable for the anchor clip (whatever it's called, who knows), and the end of the clip that holds the cable is well made where it won't come loose. The clip is good and lines up correctly with the slot in the lower column housing, and clips on fairly tightly which it needs to do.
This is the screw hole in the clip. You can see that the metal around the hole is punched through really well and has a thick lipped nipple at the hole opening. Originally this hole was blank, that is the first problem, it's not threaded at all.
This is a better close up of the height and thickness of the screw nipple. Looking at that I realized it was more than good enough to hold threads. When it was in my truck I thought I got a screw in it but in actuality the screw was just pushed in not threaded to anything. When it started sticking and I took the indicator out that's when I discovered the hole was actually blank, no kind of threads. This is a short coming on the manufacturer. So I decided to put threads in it. I did try to see if I could get a screw like a wood screw into it but it wouldn't even start. The metal is like spring steel and you just can't force a screw to make it's own threads. Sizing the hole I found it to be just right for a
8-32 tap. So I put the clip in my vice edge wise, being very careful not to crush it but clamp it firmly enough to hold it while I ran the tap down the hole. It's not real easy in that you have to be very careful not to allow the tap to suddenly slant, tearing up the start thread. This clip is almost like spring steel and it is hard. So getting the tap started is going to take a bit.
Taking my time I managed to get the tap started and down into the hole well enough to continue to run the tap all the way through well past the end of the hole so that the middle of the taps threads were engaged in the hole. This makes for a better shaped tap of the hole.
Looking at where the cable is swedged, at the end of that arm the metal is thick and it looks like it will hold.
Try not to bend this arm, it will before you know it. If it's bent, you'll be able to bend it back but it may cause the cable to misalign on the clip, where it comes out of that turn down thing you have to thread it through on the white plastic box so it will be in the correct downward angle to line up with the slot where it attaches to the lower column housing. You want the cable to slide easily through that place you have to thread it through so it hangs straight down as it comes out of that part in the white plastic box. If the arm is bent the clip may not be pulling at the right angle, where the clip is on the column.
