Adding Power Steering
Tommy
Tommy
Hello group, I've got a 78 GMC 1/2 ton SWB with a 350 that doesn't have the power steering option. I've got another square body parts truck that has power steering. My lower pulley on the engine has a place for the other belt and the head has the hole to add the power steering bracket for the pump. Will the power steering gear box mount w/o any major modifications? What other affordable options would work if this won't work. Any insight is appreciated.
yevgenievich
Place
Name
Year
Model
Size
I believe it will work but you might also need to swap the ragjoint as well. Early squares had different splines on input of the gear box
74 Shortbed
If the donor is complete it should be an easy bolt on swap.
Tommy
Tommy
Yes the donor is complete. Sounds like this should be a pretty straightforward deal. Thanks
74 Shortbed
Yes it should, unless you find wore out parts..
jbahena95
