Adding lower anchor points to the bed.
Ewhitaker0020
Kentucky
I finally installed all my anchors. I put one in each corner. I sanded and primed the areas around the anchors before installing. Also, I cut some steel plates to use on the underside of the bed to provide even more support. The anchors themselves are rated for 5,000 pounds so I should be fine.
I immediately used the anchors to strap down some poplar 2x6 rough cut lumber. Also some windows.
ExtraZ
