Add a Tach
Big Ray
North Carolina
Ray
Put an 84 tach in my 79 last year. Bought a new printed circuit, tach harness and the blue gauge housing. The 84s tabs were broken off. Used the 84 fuel gauge as well. Works fine, last long time.
84GMCSierra
Central Arizona
C2500
Huh, I looked for the combo myself, couldn't find it either. I coulda sworn LMC had it, guess I'm mistaken. If they were smart with the combo gauge it would use the power and ground connection already there for the fuel gauge. So you would just have to run 1 wire to the distributor, if that's the case (I bet it is). If not a tach only needs 3 wires, ignition switch power, ground, and the connection to the distributor. Hopefully someone who has bought on of those combo gauges can chime in.
The only combo I've seen on LMC is the one where the tach goes where the fuel gauge is. I would love a smaller tach to put in the empty spot on the lower left of my dash, that looks factory
ben_swager
