- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Here is a pic of the rear of the vacuum plug that connects to the control switch. Note the open tabs on each side. They slide over 2 plastic studs on the back of the switch and there are 2 of those spring steel stamped washer things that you push on and thy hold but are a bitch to remove. Most of the time the studs break on me but that will not hurt anything the harness does pretty good on its own holding onto the switch.
Here is a step by step you can print out and see if this helps you on your quest. You can also download onto your smart phone so you have it on hand. I have been doing this lately on any projects I been having to tackle.
AC, Heat, Vacuum, Harness, Hoses, Servo, Diagnosis, Troubleshooting, Diagram, Switch
