A weird minor problem....
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I don't know exactly what catagory to put this in, but it is certainly engine related:
Engine is a 1989 454, TBI and stock manifolds (no headers). Pulling the dipstick to check the oil is straightforward, but putting it back in has become very very difficult. Difficult to the point I am having to use a small pair of pliers to grip the dipstick about 3 inches above the tube and really apply pressure to get it to go in. Once it passes a certain point around 10-12 inches in, it then slides the rest of the way normally, but I have never had anything like this happen on any engine I've seen before. The tube does not appear to be pinched or kinked. Any one else ever have this and what causes/remedied it if you did?
nvrenuf
Mobile, Al.
There’s a rubber seal at the base of the pull ring handle, maybe it came loose and has moved down the tube?
I’d pull the tube and check for something in it before you push it into the oil pan.
GMCk2500Dalton
