A very expensive and dumb mistake
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
finally mocking up the drivetrain after setting the engine transmission and transfer case and then I saw it. I guess I just got excited about doing a one ton swap into my 87 square and just simply bought the wrong rear end. I already have 5.13 gears, arb air locker and disc brakes.the spring pads have been cut, moved and welded to fit my truck and it will not fit. I am sickened. I want to throw up. I am off the complete width of my driveshaft. This rear end is offset and not centered like I need. Will someone please tell me exactly what 8 lug full or semi float that I need to make this work please.
Here is a picture of my bowl remover.
Why not just try running it? I can't think of what they were off hand, but I know there have been factory built trucks with an offset pumpkin.
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
It would be way off center. This rear came out of a 03 2500 I believe. The yoke and pinion are off set instead of centered like I need. I don’t know what I was thinking. I had no idea it was like this.
c12r04
