99 taco 4x4
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Getting driver's side sway bar end links in & tie rods apart...they flopped around like a limp.....wrist...
Making a mess...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Got the passenger upper ball joint in...
Then got the passenger tie rods inner and outter installed....
The steering rack had fluid in the bellows....like ps fluid on pass side, and greasey substance on drivers.... I also have a small oil leak, I think from main pully's seal or oil pump area... Need to clean underside of truck to see... I hope she feels better handling wise after the alignment....
I tried to see if rack was an issue as toyota said, and it is. But no worse than before. I need a rack, but really wanted to spend my coins buying a header and SS brake lines/tundra break upgrade...
I think this will be it until tax season...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I pulled the trigger on 1" diff drop. After that she will get aligned. Then I can feel the "after".
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Original cv angle
Diff drop 1" delrin spacer
Got the inner zip ties on... There is some gunk here from a front oil pan or oil pump seepage...will fix that later...had to do it before on a 22refi
Got it aligned was way off there, but great back and much improved Handling...less sloppy wallowy
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Good to have her ready to go...
jimlayhee
