!977 K10 Bedsides
Rubber Truck
Annville PA
Justin
k-10
Just wondering how easy it is to replace the bedsides?
45tt
Florida
MJ
GMC Sierra Grande K15
It can be done, but it is time consuming. A buddy of mine did it on both sides of his 84 longbed square. He had to drill out all the spot welds to get them off and then spot weld the new sides back on at the same mount points.
DanMcG
Central NY
k10 k10
Bedsides (inner and outer panel) are easy as mentioned, but if you're talking just the skins, it's like 44tt said, it's major surgery.
Rubber Truck
Annville PA
Justin
k-10
The bedsides are bolted on with one weld at the back of the deck, easy to replace.
I am doing the whole bedside. Do they have anything where the bed floor meets the bedside?
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
Yes, there are lots of bolts under the bed floor, some are hard to get at.
The sealer at the wheel tubs can be a bit tough to get separated. But a rubber mallet should break it free.
DanMcG
Central NY
k10 k10
Everything is bolted except for a couple welds at the tailgate post like Termite-Delight mentioned.
Here are the welds on mine.
Bennyt
Surprise
Ben
The rearmost 2-4 bolts are a bit more difficult to get to.
There are usually 2 spot welds on the horizontal as shown in the picture above and two vertical. A long reach die grinder/ cut off wheel helps.
There is a little shield in the rear that needs to come off first as well as the support rods.
I would suggest doing one side at a time and making sure your gaps at the tailgate are perfect before tacking them back together. I've seen a lot of repaired beds that are crooked. I've seen a few trucks where they didn't even bother tacking them together and the owners say it holds up fine. Personally, I would tack them though.
Overall, a fairly easy job. You'll spend more time cutting off the tack welds than anything else.
Gordyg
Alberta
Gordy
Take your time and set box on a proper platform to retain level, soak bolts with nut cracker first and yes the welds are critical to t/gate opening strength and alignment. Never change just the outer. Rule of thumb, buy the most expensive complete panel and you’ll be a lot happier with the outcome.
hoagster
California
K10, 1500
5.3l
Purchased new from Auto Metal Direct, and if you have to patient not every bolt hole lines up and just for the front panel there are 20 bolts. Is it hard no just time consuming and frustrating getting it lined up and square.
ESONE
