8L90 Slip Yoke Question
84evelynrose
NOLA
Darryl
Really hoping somebody can point me in the right direction. Swapped an L87 6.2 with 8L90e 2WD into my 84 square. Trans is from a 2018 Escalade. Having trouble finding the correct slip yoke. Slip yoke I have is 32 spline and measures diameter 35.93mm. GM Part number is 12471638. I measured the inside diameter of the output shaft and it's 35.84mm. Even local Chevy dealer can't tell me if I have the right yoke. Maybe I just don't know how to install it. Not a trans expert by no means. I'm ready to order that drive shaft!
SquareRoot
What's the question?
84evelynrose
NOLA
Darryl
Not so much a question I guess. I'm hoping someone knowledgeable could help me with identifying the correct slip yoke that'll fit a converted 8L90 from 4WD to 2WD. The yoke I got (#12471638) is close but a hair too big. Part number stamped on the output shaft/tail is 24272517 if that helps. I've called around a lot and even if you could point to another source for information that would be helpful. Mike, I really appreciate you replying man. Thanks.
amandav
