- Jul 1, 2014
I certainly agree with the fuel volume issue too since it really mimics a fuel starvation problem. If it were a carbed engine, I'd be going directly for the accelerator pump. Reason I say that is because you mention mashing the gas and it falls flat on its face, then let up and it recovers.
Dumb Question, and not even sure it can be done, cuz I don't recall if the threads are different on both end or not, but you mention you replaced the fuel filter recently. Is it possible you may installed the fuel filter backwards? It would make sense to me that if the paper collapsed in the filter, it could still push the pressure but restrict the fuel volume. Did the old fuel filter seem to be restricted at all?
If I remember correctly, those filters have the same threads on both ends.
