hotrod1442
- Nov 4, 2012
- Sarnia
- Dave
- TBI 350
Does anyone have a "flow chart" to walk me through troubleshooting a "no start" condition with my '87 1500 w/TBI 5.7?
I have spark, but I'm not getting fuel @ the injectors. I cracked both fuel lines located @ back of the throttle body, and there was no fuel. I replaced the ignition module, thinking that I might not be getting the reference signal to the ECM, still no fuel.
When I turn the key to the run position, I can hear the fuel pump relay click. Should I be able to hear either of the fuel pumps (truck has dual tanks) running at this point? (I don't hear anything)
I should also mention that the truck was running poorly before the "no start" condition began. Sounded like it had an ignition miss.
I just finished changing the plugs, ohm checking the wires, and inspecting the cap and rotor, and was in the process of adjusting the ignition timing, when it suddenly just quit.
I didn't have a chance to check codes.....but the "check engine" light was on. Now, strangely, the CEL does not come on when the key is turned on, or cranked over.
Anyhow......does anyone have a flow chart to help with troubleshooting my problem.
Thanks, Dave Moon
Thanks, Dave Moon
