87 tbi 350 popping at idle and running rich
devildogcummins
forney tx
william
c3500
Truck starts up fine, at idle it will backfire out left exhaust pipe and runs rich, poor mileage. no codes. Truck has dual exhaust no cats. Did compression test and all are 168-176. Did tune up, plugs, wires, cap, rotor, ignition module, o2 sensor. all ac delco parts. no change, changed thermostate from 160 to 195, takes awhile to get up to temp but now once warm it idles with no pops but idles kinda low and rough. Acceleration is hit or miss, sometimes it pulls good sometimes sluggish. Cruises at speed fine. Has new fuel filter, going to test pressure tonight hopefully. Any more help would be greatly appreciated.
First thing I'd do is a power balance test. If you are running equally on all cylinders,I'd test fuel pressure,map sensor,coolant temperature and air temperature sensors.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Whats the injector spray pattern look like?
Should be even, fine misted upsidedown cone with no dribbles. Shine a flash light at them and watch them
gmbellew
Kansas city
glen
suburban 1500
a timing light works well for this. the strobe effect helps.
and while the timing light is out, I'd disconnect the EST and check base timing to make sure it is at 0 deg BTDC (or maybe a little more won't hurt, but you don't want less).
gmbellew
Kansas city
glen
suburban 1500
the sometimes lack of power and sometimes fine makes me think about an intake manifold vacuum leak.
also check to make sure the EGR isn't stuck open.
Octane
Atlanta
Eddie
I've had to take throttle body off and clean out dirt/ carbon from all ports.
fast 99
Spokane, Washington
Check vacuum, if low or not steady will be rich. Popping in exhaust has a myriad of causes. From ignition misfire to loose valve guides.
thom9719
