IROCmenace
- Nov 1, 2013
- TN
- Shawn
- C2500
- 350 VIN M
I am at a loss. Sorry this will be long.
This truck sat for a few years but ran before. My Dad gave it to my son so I am trying to get it running again.
Ultimately here is where I am. A mouse, or several, chewed some wires up. I have all the ones I can see reconnected.
Truck still would not start. I tested a bunch of things which led me to replacing both fuel pumps. They now both run.
The truck will run on starter fluid or if I hotwire an injector open. So I have fuel and spark.
Fuel pump relay is good
Pumps good.
All wiring for those items good.
I hooked up my scanner to the truck that can read OBD I live engine data. TPS is in range and responsive.
I understand the purple/white wire coming out of the ignition module sends a reference pulse to the ECM ground the injectors. I put a test light on the wire with my Dad cranking the truck and the test light flashed consistently.
I pulled the ECM and checked the 2 grounds, or at least what I felt were the grounds with the ECM unplugged. I tested them with a test light and they lit up.
The power side of both injectors shows 12V
I bought a Cardone ECM at Advance and replaced the ECM. No luck. Still no injector pulse. Talk about frustrating.
I replaced the dizzy as a unit 8-9 years ago. When I looked at the module today there is very little signs of wear. Truck never had much mileage put on it at any time. Just a hauler and tooling around vehicle occasionally. I pulled the module and put a different one in. It is an older GM module, I think the original one to the truck so it may or may not be good. Still no start.
I am going to get both modules tested. But from what I understand the testors only test the ignition side, not the reference side. I don't want to drop another $60 after the ECM but I may go ahead and buy another one.
I have triple checked the fuses, pulled, tested with a test light on one peg and the car battery on the other. All good.
My questions are:
Where exactly are the engine grounds. I can't find anything on them. Are they behind the heads? The ground strap from the firewall to the head is there and tight. I cannot get my hand behind the heads to feel for any other wires.
What else could this be? I tried starting it with out the TPS plugged in. Without the ECT plugged in and nothing.
TIA, I cannot think of anything else to do
Pumps good.
My questions are:
